2. OBCL Integration
2.1 Common Core Maintenances
The following are the common core maintenance that needs to be completed
for FCUBS, Payments, and ELCM systems integration.
2.1.1 Configuring Accounting System for Host Code
You can configure the accounting system using host code in the ‘Host
Parameter’ screen.
To invoke this screen, type ‘PIDHSTMT’ in the field at the top right corner
of the application toolbar and click the adjoining arrow button.
Specify the following
details
Host Code
Specify the host code.
Host Description
Specify the brief description for the host.
Accounting System Code
Specify the accounting system code.
Payment System
Specify the payment system.
ELCM System
Specify the ELCM system.
OBCL Integration System
Specify the external system. For example, OLINTSYS
2.1.2 Maintaining Integration Parameters
You have to maintain integration parameters for ‘External LOV’
and ‘ELCM/Payment/OL Utilization’. This maintenance must
be done for all branches. This maintenance is done through ‘Integration
Parameters Maintenance’ screen.
To invoke this screen, type ‘IFDINPRM’ in the field at the top right corner
Example of Integration Parameter Maintenance screen for Payments
Example
of Integration Parameter Maintenance screen for ELCM
Parameter Maintenance screen for OBCL
You can specify
the following fields in this screen:
Branch Code
Select the branch code for which the parameters are to be maintained
from the adjoining option list.
Description
A brief description of the branch code is displayed.
External System
Select the external system for which the parameters are to be maintained,
Description
A brief description of the external system is displayed.
Offset Transaction Code
Select a transaction code for the offset entry from the adjoining
option list. The adjoining option list displays all valid transaction
codes available in the system. You can select the appropriate one
Offset Amount Tag
Select an amount tag for the offset entry from the adjoining option
list. The adjoining option list displays all valid amount tag available
Amount Block Validation
Select this check box to validate the amount block. If the amount
block reference number is sent with the transaction details then the
accounting will be invoked after the release of amount block.
Offset Required
Select this check box if an offset entry is required. If this check
box is selected, then ISB GL will be resolved based on branch, currency,
function id and external system. If the check box is not selected, then
it is expected that external system sends the balanced entry
Offset Netting Required
Select this check box if offset netting entry is required. If this
check box is selected, then the consolidated entries will be built. Offset
amount tag is picked from the maintenances. If this check box is not
selected, then individual entries are built.
Allow Force Post
Select this check box to suppress all the overrides after posting
transactions.
You need to maintain the integration parameters for the following:
- External Lov – ExtLovService
- ELCM Utilization/Payments/OBCL – ELUtilizationService/PMSinglePaymentService/FCUBSCAService
External Lov
- External System - External system name is specified here. For example,
OLELCM, INTBANKING for Payments, and OLINTSYS for OBCL.
- Service Name – The service name for which the maintenance is
done. For example, ELUtilizationService for ELCM, ExtLovService for External
LovExtLovService, and PMSinglePaymentService for Payments, and FCUBSCAService
for OBCL.
- Communication Channel – The communication channel like REST,
CUSTOM, WEB SERVICE, and so on are specified here.
- Communication Mode – The communication mode can be SYNC/ASYNC.
Note
Rest Service need not be maintained for OBCL.
- Rest Service IP – You have to maintain the IP address. For
example, ELCM IP, Payment IP.
- Rest Service Port – You have to maintain port details. For
example, ELCM Port, Payment Port.
- Rest Service Pattern - You have to maintain rest service pattern.
For example, LovService
- Rest Service Context – You have to maintain rest service context.
For example, FCJNeoWeb
- External User - ELCM/Payment/OBCL user should have access to all
branches and autoauth
ELCM Utilization/Payment/OBCL
OLELCM.
LovExtLovService and PMSinglePaymentService for Payments.
- WS Service Name – The service name needs to be maintained here.
For example, ELUtilizationService, PMSinglePaymentService, and FCUBSCAService.
- WS Endpoint URL – The WSDL of the services are maintained here.
For example, ELCM utilization/Payment/CA service WSDL link
- WS User – ELCM/Payment user should have access to all branches
and autoauth.
branches and autoauth.
2.2 Oracle Lending and Loan Syndication module integration
with CASA
The integration of OLand LS module with CASA enables banks to do the
following:
- Auto Liquidation
- Manual Liquidation
- Auto Rollover
- Manual Rollover
2.2.1 Scope
This section describes the activities that take place in each system
and its impact on the other.
2.2.2 Integration Scope with FCUBS Co-deployed with OL
and LS module
If FCUBS is co-deployed with OL and LS module, then web service call
is used to check the available balance.
2.2.3 Integration Scope without FCUBS Co-deployed with
OL and LS module
The following are the integration activities that take place in Oracle
Corporate Lending.
ECA Request for Auto Liquidation
- As part of loans batch process, amount due for liquidation for a
contract must be sent to the DDA system for approval (ECA_CHECK_REQD
parameter maintained in cstb_param table and verify funds flag at contract
level). Only after receiving an approval from the DDA system, the system
proceeds with liquidation of the schedule.
- OL and LS module should send a consolidate request to the ECA one
for each contract. As the settlement account is configured for each component
in Corporate Lending, multiple settlement accounts for a contract is
possible. OL and LS module for a due date should group the total amount
due from each account and generate one ECA request for a contract and
due date.
- The due amount when sent as part of ECA request should be in account
currency.
- As part of the ECA request, OL and LS module should send the following
additional preferences configured at a contract / product level.
- Partial Liquidation Allowed (PARTIAL_BLOCK_REQUIRED): If the flag
is set as ‘N’, then ECA system should send a fail approval
in case the total amount requested is not available in the account.
- In case of multiple schedules that are due from the customer as part
of Auto Liquidation, OL and LS system should place a ECA request for
the earliest schedule due from the customer. Only when the schedule is
completely settled and processed in OL system, request for next schedule
should be placed.
- First process in OL and LS batch would compute the amount due for
a schedule as part of Auto liquidation and place the request into ECA
table with the current status as ‘Unprocessed’. A Java program
would constantly poll the table for any unprocessed records and transform
the records into an ECA request XML and place the same into a IN queue
of the external system configured.
- Upon receipt of any response from the DDA system in the OUT queue
of OL and LS module, the response would be parsed by the JAVA program
and update the status response status (Approved/Rejected) in OLTB_ECA_REQ_MASTER
and OLTB_ECA_REQ_DETAIL table.
- When ECA block is successfully created on the accounts (Partial /
Full), liquidation happens in OL and LS module and perform OL and LS
accounting with handoff status as 'N'.
- ECA request for auto liquidation should not be created when future
dated payment is requested for the same contract. ECA request for auto
liquidation should not be created from OL and LS module where GL is chosen
as settlement account. For example, for a contract having Principal and
Interest as components and GL is chosen as a settlement account then
no ECA request should be created by OL and LS module. However, if GL
is chosen only for Interest and for Principal a valid customer account
is chosen as settlement account, then ECA request should be created only
for Principal component.
- When Auto Liquidation process is run for more than one day as part
of EOD processing (due to holiday settings), then Auto liquidation for
the schedules that are due for a day can be processed only after Auto
liquidation is processed successfully for the preceding day.
- In a situation where ECA block is successful, but subsequent processing
in OL and LS module fails auto retry mechanism should be available in
OL and LS module.
ECA Handling during Auto Rollover
- For contract marked for Auto Rollover, after EOD process of Auto
Liquidation, a new sub-process ‘AROLL’ is introduced to process
Auto Rollover on processing date
ECA Handling for Manual liquidation
- After you capture the necessary payment details and click ‘Save’,
OL and LS module should place an ECA request for the amount requested
for the payment.
- There should be an additional field in the payment screen to display
the ECA process status. This should display the status of the ECA request.
- When the ECA request is approved by the DDA system, it needs to be
manually authorized. Hence, manual payment is deleted for unauthorized
contract, an undo ECA should be sent to the DDA system.
- OL and LS module should process the payment request and update the
cashflow tables and post liquidation entries as part of back ground process
and payment status will be in unauthorized state.
- Authorisation of payment is possible only after the liquidation process
is completed and entries are posted.
- Similarly OL and LS module should generate reversal entries upon
reversal of loan payment. In case where actual accounting to DDA system
is not generated post ECA approval, OL and LS module should generate
both actual entries for liquidation with block number and its reversal.
Actions
System Response
After logging payment in
ECA queue for approval, if you try to delete the payment before getting
the response, then the status is W.
The system should undo
ECA if it gets approved response (Reconcillation mechanism)
After getting ECA response
as ‘Approved’, if you try to delete the payment
ECA with the approved block number
ECA Handling for Manual Rollover
- After you initiate the rollover (Normal/Consol/Split) through application,
OL module should place an ELCM request (if any limits are linked to the
contract) for the amount to be debited from customer.
- After success response from the ELCM system, the system allows you
to authorize the rollover. In case where actual accounting to DDA system
is not happened post ECA approval, OL and LS module should generate both
actual entries for roll event with block number to release from DDA system.
Account Interface and Handoff
- For CASA, where debit happened excluding force debit components,
have the block number in the daily log table.
- As part of accounting interface OL and LS module should hold two
handoff status, one to indicate whether the customer account related
entries handoff to DDA system and another to indicate GL entries handoff
to GL system.
- External Account Check (EAC) is done wherever the credit happens
to CASA account to avoid failure in external system side (Check for No
credit, No debit,Frozen,Deceased)
- Java poller constantly polls the daily log table and pick the records
which are authorized and handoff yet to be done.It then generates the
accounting request with necessary details and put in IN queue.After getting
successful response from external system, handoff status is changed.If
anything failed while giving external handoff, external system throws
a proper exception code and same has been logged in OL and LS side.
Debit request+ <ECAREFNO>
ECA Block is released
Debit request
Amount is debited from
withdrawable balance
- Credit and Debit advice should be generated only after the feedback
from the DDA system after posting entries to the customer account.
- OL and LS module should be capable to handoff the entries online
by generating XML request as well as handoff entries through batch process
at regular intervals during the day.
Force debit Components
Tax, Fee and charge which are associated with liquidation/rollover
event is debited from the account without ECA.
Forward Liquidation
- As part of loans batch process, amount requested (From payment screen)
for liquidation of a contract must be sent to the DDA system for approval
(ECA_CHECK_REQD parameter maintained at cstb_param, Branch Param, and
CASA level table and verify funds flag at contract level). Only after
receiving an approval from the DDA system, the system proceeds with liquidation
of the schedule.
- First process in OL and LS batch( for Fwd liquidation) ,would compute
the requested amount for a contract and place the request into ECA table
- When ECA block is successfully created on the accounts (Full), liquidation
happens in OL module and perform OL accounting with handoff status as
'No'.
- ECA request for liquidation should not be created from OL and LS
module where GL is chosen as settlement account. For example, for a contract
having Principal and Interest as components and GL is chosen as a settlement
account then no ECA request should be created by OL and LS module. However,
if GL is chosen only for Interest and for Principal a valid customer
account is chosen as settlement account, then ECA request should be created
only for Principal component.
OL and LS module.
2.2.4 ECA handling scenarios for Corporate Loan Liquidation
2.2.4.1 Single CASA Account with Full
liquidation
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.4.2 Different CASA Account with Full Liquidation
In this case OL and LS module generates a single ECA request that
contain details amount due from two accounts.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA2
10000
2.2.4.3 GL Account used for Liquidation
In this case request is not sent to ECA system, however it is marked
as approved by OL and LS module in ECA tables and it proceeds with liquidation
processing.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
GL1
50000
Interest
10000
GL2
10000
2.2.4.4 One CASA and GL Account used for Liquidation
In this ECA request is sent only for CASA account and the GL it is
marked as approved automatically. Liquidation processing happens irrespective
of whether the ECA request is successful for the CASA account.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA
50000
Interest
10000
GL1
10000
2.2.4.5 Single CASA Account with Partial Liquidation
In this case, the system proceeds with allocating the approved amount
based on liquidation order specified at the product level.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.4.6 Manual Liquidation with Single CASA or Multiple CASA
Account
In this case ECA request is sent with Partial allowed as ‘N’,
hence the request is marked as failure if the full amount requested is
not available.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.5 Prerequisites
2.2.6 Prerequisites in Oracle Lending and Loan Syndication
The prerequisites for this integration are as follows.
2.2.6.1 Parameter Setup
- If HANDOFF_TYPE value is ‘SYNC’ in CSTB_PARAM table,
then the balance check is performed using API or dynamic call.
- If HANDOFF_TYPE value is ‘ASYNC’ in CSTB_PARAM table,
then the consolidated amount to be requested is logged in ECA tables.
Further processing, is performed by job.
- ECA_CHECK_REQD should be 'YES' in CSTB_PARAM table for standalone
system.
2.2.6.2 Maintenances
Complete the following maintenances in Oracle Banking Corporate Lending
to enable the integration.
Queue Name
Purpose
ECA_REQ_OUT
Request to external system
ECA_RES_IN
Response from external
system
Table Name
Purpose
COTB_ECA_QUEUE
ECA request details
COTB_ECA_QUEUE_DETAIL
ECA request components
details
Note
The following data in OL and LS module must be in
sync with those maintained in external system.
- Branch
- Contract Reference Number
- Account number
- Currency
- Dr/Cr
2.3 Integration Process of OL and LS module CASA
2.3.1 Viewing ECA Queue Summary Details
ECA Queue Summary screen contains details on the transactions between
OL/LS and external system.
To invoke this screen, type PISECAQU’ in the field at the top right corner
You can search records
based on the following parameters:
- Transaction Reference No
- Network code
- ECA Amount
- Customer No
- Requested Date
- Authorization Status
- Cross Border Contract Reference Number
- Activation Date
- File Reference Number
- Payment Transaction Type
- ECA Currency
- Current Status
- Response Date
- Maker Id
- Payment Type
- Customer Service Model
- Queue Reference No
- Transaction Branch
- Module
- Response Status
- ECA System Code
- Checker Id
- Source Code
Click ‘Search’ button with or without entering any of
the above search parameters. All records matching the search criteria
are displayed. To view a particular record double-click on the desired
record displayed in the list of records. The details pertaining to each
record is displayed.
2.3.2 Viewing External Accounting Log
'External Accounting Log' screen contains OL/LS transaction details
with External Accounting System linkage.
To invoke this screen, type ‘OLSEACLG’ in the field at the top right corner
In this screen, you can view the request sent from OL and LS module
and view the response (received for the request sent) from the External
Accounting System.
- External Reference Number
- Branch
- External Accounting System
- Operation Code
- Process Status
- Message Reference Number
2.4 Integration with FCUBS for 360
Degree Customer View
Using 360 Degree Customer View, you can query customer limits, account
statements, view settlement balances contracts, view assets and liability
balances, view loans, commitments and syndication contract details of
the customer. You can also view summary of loans, commitments and syndication
contract details of the customer. The 360 degree customer view facilitates
easy and total view of the customer details and reduces customer service
complexities.
FCUBS pulls the required data from OBCL by using the below operation
code.
- Service Name : FCUBSOLService
- New Operation : QueryCorpCustview
2.4.1 Summary Tab
The ‘Summary’ tab displays the OBCL loan contracts of
the selected customers along with the details.
2.4.2 Loans Tab
In an FCUBS – OBCL integrated environment, click ‘Loans’
tab in ‘360 degree customer view’ screen to view the details
for OBCL contracts in Loan details/Commitment and Syndicate Loan Details
block for the selected customer.
The loans
details are classified as follows:
- Commitment Details
- Loan Details
- Mortgage
- Leasing
- Syndicate Loans details
Under each of the loan details, the system displays the following:
- Branch Code
- Account Number
- Description
- Currency
- Amount Financed
- Amount Disbursed
- Outstanding Amount
- Book Date
- Value date
- Maturity Date
- Product Code
- Account Status
- User Defined Status
2.4.3 Component Details Button
You can view details about the components linked to an account in
the ‘Component Details’ screen. You can invoke this screen
by clicking the ‘Component Details’ button in the ‘360
Degree Retail Customer View’ screen.
You
can view the following component details:
- Component Name
- Component Currency
- Expected – the system displays the amount which is not due
for the present date. This amount is arrived during querying.
- Overdue – – the system displays the amount which is
not overdue for the present date. This amount is arrived during querying
- Outstanding – the system displays the amount which is due for
- Advance – the system displays the amount pre paid for a component
as on the present date. This amount is arrived during querying.
- Latest Interest rate – the system display the current interest
rate only for main interest component.
- Number of Days Overdue.
Here you can view the following:
- Component Name
- Schedule Due Date
- Due amount
- Settled Amount
- EMI Amount
- Accrued Amount
2.5 OBCL Integration with Payments
for SWIFT messages
The integration between Oracle Banking Corporate Lending and Oracle
Banking Payments enables you to generate SWIFT messages (MT103 and MT202)
for Corporate Lending through Payments module.
2.5.1 Scope
SWIFT payment message MT103 and MT202 are supported. If transfer type
is ‘Customer Transfer’, then MT103 payment message is generated.
If transfer type is Bank Transfer, then MT202 payment message is generated.
2.5.2 Integration Process of OBCL
and Payments
For OL/LS with Payments integration, you need to perform the following:
- In Branch Parameters Details screen (OLDBRMNT), 'Generate MT103' check box needs to be
selected.
- In Settlement Instructions Maintenance (LBDINSTR), 'Transfer By Pay' or 'Transfer By Recv'
needs to be selected as ‘BANK’ or ‘CUSTOMER’.
In case of 'BANK', MT202 SWIFT message is generated at Payments module.
In case of 'CUSTOMER', MT103 SWIFT message is generated at Payments module.
- OBCL initiates web services call, that is, PMSinglePaymentService
call for cross-border outgoing SWIFT transactions. These outgoing SWIFT
transactions are processed by Payments module. The payment module generates
MT103 and MT202/MT202Cover SWIFT messages.
- The system allows the cancellation request to be passed to OBPM when
the loan contract is reversed from OBCL. The service "PMOutTxnReversalService"
is called from OBCL to pass the cancellation request and after the contract
gets reversed in OBPM, the payment system sends the reversal handoff
notification to OBCL to pass the actual reversal entries. Thus, the cancellation
message (MTn92) from OBPM is supported.A new batch job is introduced
that allows the payment message request to be passed to OBPM for the
future dated loan contracts/Value Dated Amendments for any principal
increase originated from OBCL considering the settlement generation days.
Service "PMSinglePayOutService" is called from OBCL to pass the future
dated request and after the transaction gets processed in OBPM, the payment
system sends the payment message on SGEN date itself. Hence, generation
of future dated Payment messages (MT103/MT202) from OBCL is supported.
In Loan Syndication, SWIFT messages are triggered based on the components
like PRINCIPAL, INT_LIQD, and FEE_LIQD.
For Loans - Payments integration, beneficiary charges on payment is
sent as part of Single Payout Service (SPS OUT) and also accounting entries
are displayed that are handed off from OBPM in Contract Online Screen
(Events > Accounting Entries tab).
2.5.2.1 Processing of Outgoing SWIFT Messages
Steps involved in processing of outgoing SWIFT messages.
- On save of the contract, the system checks if SWIFT messages are
generated and Inter System Bridge GL (ISB GL) maintenance is available.
- Instead of posting accounting entries to settlement account, the
system posts accounting entries to ISB GL.
- On authorization, the system populates SWIFT related details to staging
table. Job runs on the table and pick these records. These details are
sent to Payments module.
- Once the request is received, Payments module sends the response
with confirmation.
- Payments module sends communication to OBCL for each of these actions.
- Using same service, Payments module sends SWIFT messages ACK/NACK
accordingly. Once SWIFT message is received, OBCL populates the daily
out message table.
- After OBPM hand off, the accounting entries are shown in “Accounting
Entries” sub screen of Contract and Commitment - Contract Input’
screen (OLDTRONL). The “Accounting System” field shows either
‘Loans’ or ‘Payments’. The accounting entry passed
after OBPM hand off is - debit inter bridge GL account and credit customer
settlement account.
- You can view these messages in ‘Payment Outgoing Browser’
screen.
2.5.2.2 Viewing Payment Integration Request/Response Messages
You can view Oracle Lending and Loan Syndication contracts with payment
integration in ‘Payment Outgoing Browser’ screen.
To invoke this screen, type ‘OLSPMTBR’ in the field at the top right corner
In this screen, you can view the request sent from Oracle Lending/Loan
Syndication module and view the response (received for the request sent)
from the Payments module.
- Queue Reference Number
- Sequence Number
- Process Status
- Value Date
- Event Code
Note
To search outgoing payment details, for LB side use
DD Contract Reference Number and for LP side use Contract Reference Number
2.5.2.3 Maintaining ISB GL
You can invoke the ‘ISB GL Maintenance’ screen by typing
‘OLDISBGL’ in the field at the top right corner
of the application tool bar and by clicking the adjoining arrow button.
You can specify the
following field information in this screen. A brief description of each
value updated in the fields appearing in this screen, is displayed by
the system.
External System
Select the external system from the adjoining option list.
Module ID
Select a valid module code from the adjoining option list.
Transaction Currency
Select a valid currency code from the adjoining option list.
Transaction Branch
Select a valid transaction branch code from the adjoining option list
Product Code
Select a valid product code from the adjoining option list.
Function ID
Select a valid function ID from the adjoining option list.
ISB GL
Select a leaf General Ledger from the adjoining option list.
2.6 OBCL - ELCM Integration
The integration between OBCL and ELCM enables you to view the Oracle
Lending and Loan Syndication contracts with ELCM linkage in a sync or
async mode.
2.6.1 Scope
If you are booking a Oracle Lending and Loan Syndication contracts
with ELCM linkage in a sync or async mode, the OLTB_REQ_MASTER table
is updated with records. You can view these records in the External Limit
Summary screen.
2.6.2 Prerequisites
OLTB_REQ_MASTER table must have value.
2.6.3 Integration Process of OL and
ELCM
Forward Init
As part of loan batch process for contract marked for initiation
on processing date, the system picks and processes the 'FWDINIT' on processing
date.After processing ‘FWDINIT’, the system sends a request
to ELCM system (if any limits are linked to contract) for Utilization
of contract amount.
After success response from the ELCM system, the system authorizes
the ‘FWDINIT’ process.For failure response from ELCM system,
the system roll backs the ‘FWDINIT’ process (after roll back
contract details are logged into exception table)
Forward VAMI
As part of loan batch process for contract marked for VAMI on processing
date, the system picks and processes the ‘FWDVAMI’ on processing
date. After processing FWDVAMI, the system sends a request to ELCM system
(If any limits are linked to contract) for Utilization/De-Utilization
of contract amount.
the VAMI process. For failure response from ELCM system, the system roll
backs the FWDVAMI process (after roll back contract details are logged
Auto Liquidation and Forward Liquidation
As part of loan batch process for contract marked for Liqudation on
processing date, the system picks and processes the liquidation on processing
date. After processing the system sends a request to ELCM system (If
any limits are linked to contract) for Utilization/De-Utilization of
contract amount.
After success response from the ELCM system, the system completes
the liquidation process. For failure response from ELCM system, the system
roll backs the liquidation process (after roll back contract details
ACCRUAL
As part of loan batch process for contract marked for ‘ACCRUAL’
on processing date, the system picks and processes the ‘ACCRUAL’
process on processing date. After processing accrual process, the system
sends a request to ELCM system (If any limits are linked to contract)
for Utilization/De-Utilization of contract amount.
the accrual process. For failure response from ELCM system, the system
roll backs the ‘ACCRUAL’ process (after roll back contract
details are logged into exception table).
2.6.3.1 Viewing External Limit Summary
Details
External Limit Summary screen contains details of the Oracle Lending
and Loan Syndication transactions with ELCM linkage.
You can approve, resend, reject, and authorize the Oracle Lending
and Loan Syndication transactions using this screen.
To invoke this screen, type OLSEXLMT’ in the field at the top right corner
- Branch Code
- User Reference Number
- Message ID
- Process Sequence Number
- Process Status
- External Status
- Destination Source
- Request Type
- Forceprocess
- Service Code
- Logtime
- Maker ID
- Maker Date Stamp
- Checker ID
- Checker Date Stamp
2.6.3.2 Viewing Action Log of External
Limit Queue
The action log screen displays the details of actions performed in
the External Limit Queue screen.
To invoke this screen, type ‘OLDQAHIS’ in the field at the top right corner
This screen displays
the action log of the following fields along with ‘Message Id’
and ‘Process Sequence Number’.
- Transaction Reference Number
- Previous Status
- Current Status
- Logtime
- Maker ID
- Maker Date Stamp
- Checker ID
2.6.4 Viewing Service Log Details
You can view service log using ‘View Service Log’ screen.
To invoke this screen, type ‘OLDSRLOG’ in the field at the top right corner
2.7 Common Integration Details Summary
screen
You can view the contract integration status of various modules (OL,
LB, LP, FC, TL) of OBCL and also connect to integration screen of different
product processors.
You can invoke the ‘OL Interface Summary’ screen by typing
‘OLSCNSTS’ in the field at the top right corner
of the Application tool bar and clicking the adjoining arrow button.
To view the details,
query using any of the following fields.
- Branch Code
- Contract Number
- Module Code.
You can select the specific contracts and then click their respective
product processor sub-system.
- ELCM Details - External Limit Queue (OLSEXLMT)
- ECA Details - ECA Status View (PISECAQU)
- Accounting Details - External Accounting Entries Browser (OLSEACBR)
- Payment Details - Payment Outgoing Browser (OLSPMTBR)
- CD Details - Transaction Log (OLSIFCD)
After going to the integration screen, you can re-process and verify
the logs of various contracts.
For more information on CD Details - Transaction Log (OLSIFCD), refer
to FCUBS Corporate Deposit -OBCL Integration User Guide.
2.8 OBCL Integration with FCUBS for
EAC
The integration between OBCL and UBS enables to handle the External
Account Check (EAC) and customer status for the counterparty of the contract
in synchronous mode.
2.8.1 Scope
The customer accounts are validated as part of EAC process during
contract booking, VAMI, payment, rollover, and so on. The following are
the list of operations supported.
Operation
Online/Batch
Customer Status
EAC Process
Contract Booking
Online
Yes
Yes
Contract Amendment
Online
Yes
Yes
Value Date Amendment
Online
Yes
Yes
Rollover
Online
Yes
Yes
Payment
Online
No
Yes
Manual Disbursement
Online
Yes
Yes
Linkage Amendment
Online
Yes
No
Fee Liquidation
Online
Yes
Yes
Split Reprice
Online
Yes
Yes
Consolidate Reprice
Online
Yes
Yes
Consolidate Rollover
Online
Yes
Yes
FWD INIT
Batch
Yes
Yes
FWD VAMI
Batch
Yes
Yes
Auto Disbursement
Batch
Yes
Yes
Auto Rollover
Batch
Yes
Yes
Auto LIQD
Batch
No
Yes
2.8.2 Prerequisites
- For EAC, OBCL uses ‘CreateEACAccVal’ service
available in UBS. This service validates the customer and customer account
provided in the request.
- To validate the customer status of the counterparty, OBCL
uses the ‘QueryCustomer’ service in UBS and validate the
frozen/deceased/where about unknown status.
- A parameter ‘OBCL_EXTERNAL_ACC_CHK_REQ’ is
introduced in CSTB_PARAM table. By default this flag is set to ‘Y’.
If this flag is enabled, then the system verifies EAC check and customer
status during transaction online/batch.
- Static INC to support EAC in OLTM_SERVICE_PARAMS and OLTM_SERVICE_REQ_FORMAT
tables
- Integration maintenance for EAC in OLDINPRM
2.8.3 Integration Process of EAC and
Customer Status
EAC process
- This integration is to verify the settlement account and account
CIF in a contract. This service validates the customer and customer account
and returns success or fail.
- The synchronous call request is inserted into OLTB_REQ_MASTER with
process status as ‘U’.
- New stage table contains the tag values required to build the request
for each contract
- OLTB_EAC_ACC_MASTER
- OLTB_EAC_ACC_DETAIL
- The system validates account CIF or account based on few parameters
(frozen/dormant/no debit/no credit, and so on) and an appropriate error
message appears.
Customer Status
- This integration is to verify the frozen, deceased and where about
unknown status for the counterparty and Borrower CIF of a contract.
- New stage table contains the tag value required to build the request
for each contract
- The system validates the counterparty and borrower based on few parameters
(frozen/deceased/where about unknown/invalid customer) and an appropriate
error message appears.
Inactive Customer Status
If a customer does not have any single contract active, then an update is sent to FCUBS using
"QueryCustSts" service. "QueryCustSts" service is consumed by OBCL to handoff the
customer status (Active/Inactive) to FCUBS system.
