About the Database Configuration Wizard for P6
The Database Configuration wizard enables you to change the database connection settings you specified when you installed P6.
The database you select during configuration stores one or more P6 EPPM configurations, each one specifying a set of parameters that determine how P6 operates. During configuration, you select an existing P6 EPPM configuration or create a new one. Later, you can use the Database Configuration wizard to select a different P6 EPPM configuration or create a new one.
Notes:
Related Topics
Changing Database Connection Settings for P6
Last Published Friday, February 2, 2024
