Configuring User Productivity Kit Settings in Application Settings
To set your User Productivity Kit (UPK) settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Application/User Productivity Kit.
    1. Select Enable User Productivity Kit to allow tutorials to be available within P6 EPPM.
      Note: See the documentation included with Oracle UPK (User Productivity Kit) for details on In-Application Support.
    2. In the User Productivity Kit URL field, enter the URL used to launch UPK content.
      Notes:
      • The URL might be case-sensitive, depending on your application server configuration.
      • WebLogic requires that the name of the UPK file stay the same when a custom UPK file is deployed. If you change the file name, you must create a new domain in WebLogic to match the name of the new UPK file.
      • A UPK URL entered here is used for both P6 and P6 Team Member Web. A separate P6 EPPM configuration must be made to use different content in these products.
Related Topics
About Application Settings in the Primavera P6 Administrator
Manage Access to Multiple Database Instances
Configuring Application Settings in the Primavera P6 Administrator
Last Published Friday, February 2, 2024
