Configuring Module Access Service in Services Settings
If you are running services and P6 on the same server, you should keep the defaults. If you want to apply the service immediately, you should set the rates low (for example, 30s). Remember that if the server is actively applying the service, all users will experience delays in the application.
To set your module access service settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Services/Infrastructure Services.
    1. In the Update Rate field, enter the rate when a Business Rule Engine synchronizes with the database for license counts.
      The default value is 30s.
      Enter a value between 100 and 1m.
    2. In the Expiration Check Rate field, enter the rate when the database checks licenses to see if they should expire.
      The default value is 2m.
      Enter a value between 500 and 15m.
Related Topics
Configuring Infrastructure Services in Services Settings
Configuring Timestamp Service in Services Settings
Configuring Mail Service in Services Settings
Configuring Registry Service in Services Settings
Configuring Next Key Service in Services Settings
Configuring Alert Notification Service in Services Settings
Configuring Collaboration Synchronization Service in Services Settings
Configuring Asynchronous Jobs in Services Settings
Configuring Project Hierarchy Cache in Services Settings
Last Published Friday, February 2, 2024
