Configuring Leveler in Services Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator > About the Primavera P6 Administrator Services Settings > Configuring Job Services in Services Settings
If you are running services and P6 on the same server, you should keep the defaults. If you have leveling work that needs to be done immediately, you should set the Interval low (for example, 10s) and the Concurrent Threads high (for example, 20). Remember that if the server is actively doing leveling work, all users will experience delays in the application.
To set your leveler settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Services/Job Services.
- Select Leveler.
- In the Interval field, enter the amount of time the Web Leveler will wait before leveling the next available job (in 1d1h1m1s format, specifying only numbers without letters indicates milliseconds).
The default value is 10s.
Enter a value between 1s and 24d20h31m23s647.
- In the Concurrent Threads field, enter the number of processes (active levelers) used for leveling on this server. A value of 0 indicates this server will not perform leveling.
The default value is 2.
Enter a value between 0 and 20.
- In the Active Mode field, select true if you want jobs processed continuously until all jobs are leveled. Select false if you want each job processed according to the Leveling Interval.
Related Topics
Configuring Scheduler in Services Settings
Configuring Summarizer in Services Settings
Configuring Apply Actuals in Services Settings
Configuring Unifier in Services Settings
Configuring Overallocation Check in Services Settings
Configuring Global Replace Service in Services Settings
Configuring CopyProject in Services Settings
Configuring Baseline in Service Settings
Configuring GatewaySynchronization
Configuring Store Period Performance in Services Settings
Configuring Recalculate Assignment Cost in Services Settings
Configuring Rename Document Folder in Services Settings
Configuring CopyWBS in Services Settings
Configuring Export Excel in Services Settings
Configuring Import/Export Enterprise Data in Services Settings
Configuring Generate Reports in Services Settings
Configuring Checkin Enterprise Data in Services Settings
Configuring Checkout Enterprise Data in Services Settings
Configuring Preview Baseline in Services Settings
Last Published Friday, February 2, 2024
