Configuring Integration API Server Settings
To configure P6 Integration API and P6 to work together, you will need to set the P6 Integration API settings in the Primavera P6 Administrator.
Note: For more information on the Primavera P6 Administrator see Primavera P6 Administrator Setup Tasks.
To set your Integration API server settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Integration API Server.
  4. In the Session Timeout field, enter the number of minutes when an idle connection will end.
    The default value is 120.
    Enter a value between 1 and 24d.
  5. In the Security Authenticate Mode field, select one of the following modes:
    Username Token Profile
    SAML Token Profile
    The default value is Username Token Profile.
  6. To configure RMI settings:
    1. Select Enable to enable the RMI server. You need to enable the RMI server only if you are using P6 Integration API.
    2. P6 Integration API supports three modes. Depending on the mode you are using, do one of the following:
      • Select Enable Compression to enable compression service mode.
      • Select Enable SSL to enable SSL service mode.
      • Select Enable Standard Service to enable Standard service mode.
    3. In the Registry Port field, enter the port for the RMI Registry. The default value is 9099.
    4. Depending on which mode you enable, set the corresponding port for that mode:
      • In the Compression Service Port field, enter the port to use for Compression service mode. A setting of 0 indicates that any available port will be used. If the server will be accessed across a firewall, you must set this to a specific port.
        The default value is 0.
      • In the SSL Service Port field, enter the port to use for SSL service mode. A setting of 0 indicates that any available port will be used. If the server will be accessed across a firewall, you must set this to a specific port.
      • In the Standard Service Port field, enter the port to use for Standard service mode. A setting of 0 indicates that any available port will be used. If the server will be accessed across a firewall, you must set this to a specific port.
  7. In the File Location field, enter the full path to the Keystore file.
  8. In the Keystore Password field enter the Keystore password.
Related Topics
P6 Integration API Setup Tasks for On-Premises
Changing Database Configuration Settings for P6 Integration API
Enabling the Java Security Manager
Configuring P6 Integration API Authentication
Last Published Friday, February 2, 2024
