Reviewing and Modifying Configurations for P6
The Primavera P6 Administrator presents configuration settings for your P6 EPPM applications. The Configurations and Authentication tabs display the current configurations and settings. The Log tab displays a history of configuration changes.
Tips
- Position the mouse over a setting to read the description.
- You cannot edit the Factory Default configuration settings. You can only modify custom configurations.
- The Primavera P6 Administrator warns you of any out of date configurations. Oracle recommends that you update these configurations.
- If you create a new configuration, you need to click Update to latest version before changing your settings in the new configuration.
- To find a setting quickly, you can use the search box below the Configurations drop-down list. Clicking the search button or hitting enter will open every file with that setting name.
Related Topics
Changing a Setting in the Primavera P6 Administrator
Returning a Primavera P6 Administrator Setting to its Default Value
Adding Configurations to the Primavera P6 Administrator
Adding Database Instances to a Configuration in the Primavera P6 Administrator for On-Premises
Exporting Configurations Using the Command Line for On-Premises
Last Published Friday, February 2, 2024
