Adding Additional Policies to Oracle Web Services Manager
By default, the P6 EPPM Configuration Wizard deploys P6 EPPM Web Services with the oracle/wss_username_token_server_policy OWSM policy. This policy does not contain message protection and encryption.
To add a new policy to OWSM for message protection and encryption:
- Create a Java Keystore.
For information about Java keystores and instructions to create one, refer to the SAML Message Protection Use Case chapter of the Oracle Fusion Middleware Securing Web Services and Managing Policies with Oracle Web Services Manager guide on Oracle Technical Network.
- Configure OWSM to use the JKS Keystore.
For information about Java keystores and instructions to create one, refer to the Managing OWSM Domain Configuration chapter of the Oracle Fusion Middleware Securing Web Services and Managing Policies with Oracle Web Services Manager guide on Oracle Technical Network.
- Log in to WebLogic Enterprise Manager using the following URL:
http://<Host_Name>:<Port>/em
- Navigate to WebLogic Domains in the Target Navigation directory and right-click owsm.
- In the owsm menu, select Web Services and then click WSM Policy Sets.
- Select P6WSSOAP and then click Edit.
Note: Edit becomes available when a policy set is selected.
- Add additional policies to the policy set by completing the following:
- On the Edit Policy Set: Enter General Information page, click Next.
- On the Edit Policy Set: Enter Resource Scope page, click Next.
- On the Edit Policy Set : Enter Constraint page, click Next.
- On the Edit Policy Set: Add Policy References page, attach one of the following policies from the Available Policies table and then click Next:
- oracle/wss11_username_token_with_message_protection_server_policy
- oracle/wss11_saml20_token_with_message_protection_server_policy OWSM
Note: Refer to OWSM documentation for descriptions of each policy.
- On the Edit Policy Set: Summary page, click Save.
- Navigate to P6WebServices in the Target Navigation directory.
- Click Apply JRF Template.
- Restart the P6 server.
Related Topics
P6 EPPM Web Services Setup Tasks
Changing Database Configuration Settings for P6 EPPM Web Services
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Last Published Friday, February 2, 2024
