Configuring Delete Published Data in Services Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator > About the Primavera P6 Administrator Services Settings
If you are running services and P6 on the same server, you should keep the defaults.
To set your delete published data settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Services/Publication/Delete Published Data.
- In the Interval field, enter the amount of time the DeletePublishedData service will wait before scheduling the next available job (in 1d1h1m1s format, specifying only numbers without letters implies milliseconds). When P6 initiates the DeletePublishedData service, it will attempt to run immediately but switch to running as a job service if it takes too long to start.
The default value is 10s.
Enter a value between 1s and 24d20h31m23s647.
- In the Concurrent Threads field, enter the number of processes used for the DeletePublishedData service on this server. A value of 0 indicates that the service is not available on this server.
The default value is 2.
Enter a value between 0 and 20.
- In the Active Mode field, select true if you want jobs processed continuously until all jobs finish. Select false if you want each job processed according to the Interval.
Related Topics
Configuration for ASAP and Scheduled Services
Configuring Publication Settings in Services Settings
Configuring Publication Services in Services Settings
Configuring Infrastructure Services in Services Settings
Configuring Job Services in Services Settings
Last Published Friday, February 2, 2024
