Create document categories (P6 Professional Only)
Defining Administrative Categories (P6 Professional Only) > Document Categories (P6 Professional Only)
You can set up categories to assign to work products and documents.
- Choose Admin, Admin Categories.
- Click the Document Categories tab, then click Add.
- Type the name of the new document category.
Tip
- To change the order in which document categories are listed, select the document category you want to move, then click Shift Up or Shift Down.
Last Published Tuesday, December 12, 2023
