Export a project for use with Oracle Primavera Contractor
You can export a P6 Professional project to XER format, then import the XER project to Oracle Primavera Contractor 5.0 or 6.1 or later. You cannot import an XER file to an earlier version of Oracle Primavera Contractor than 5.0.
  1. Open the project you want to export.
  2. Choose File, Export.
  3. Choose Primavera Contractor - (XER).
  4. Select the appropriate version from the pull-down menu. Click Next.
  5. Choose Project.
  6. Mark the Export checkbox for the project you want to export.
    You can only select one project.
  7. Type the name of the export file and the location where the file will be saved.
  8. Click Finish.
  9. Click Close.
Notes
Related Topics
Data not exported to Oracle Primavera Contractor
Last Published Monday, November 6, 2023
