Import a project in XML format
  1. Choose File, Import.
  2. Choose Primavera P6 - (XML). Click Next.
  3. Select the file you want to import. Clear the option "Import all project level layouts" if you do not need them to be included with the project. Click Next.
  4. Click the Import Action field and use the drop-down menu to choose how the project data is imported.
    Select Update Existing Project to add any new or modified data in the XML file to an open project.
    Select Create New Project to create a new project without changing existing projects.
    Select Ignore this Project to not import the selected projects.
  5. When P6 Professional is connected to an EPPM database, click the Currencies import in field and use the drop-down menu to choose how currencies are imported.
    Select Base Rate to import cost data in the base rate for your database. Choose this option if you do not want costs to be converted using the exchange rates in the XML file and your database.
    Select XML Rate to import cost data and convert it using the exchange rate in the XML file and your database. Choose this option if you want cost to be converted to account for differences in the exchange rate between the originating database for the XML file and your database.
  6. Double click the Import To field and specify where to import the project.
  7. Double click the Baselines to Import field. In the Baselines to Import dialog box, mark the Import checkbox next to each baseline you want to import. Click OK, then click Next.
    Note: If you select to import with the update existing option and you select to import baselines, matching baselines will be updated with the data from the XML file according to the options in the selected template. Baselines you choose to import but which do not have a match in your database against the project you selected to update will be added to the project.
  8. If you chose to create a new project, double click the Financial Period Calendar Field. In the Select Financial Period Calendar box, select an appropriate financial period calendar (if necessary).
  9. Choose the data to import by adding or editing a template in the Update Project Options dialog box (if necessary).
    In the Update Project Options dialog box, you can search for templates using the Search field. As you type, it will filter only those templates that match the text in this field.
  10. Click Edit to launch the Import Options dialog box.
  11. On the Basic tab of the Import Options dialog box, modify the selected option by choosing the action to take when the same data exists in the import file and the project being updated. If resource security is enabled, some restrictions apply when importing activity resource assignments.
    Select the action to perform during the import process. Mark the Delete checkbox to remove unreferenced data (that is, data in the project you are updating but is not included in the import file) from the project. (The Delete field applies only to relationships to external projects, thresholds, activities, activity relationships, and activity resource assignments. Global data types are not affected by this setting.)
  12. On the Advanced tab of the Import Options dialog box, modify global data, including codes, UDFs, calendars, and resources, as necessary.
    Note: This tab is disabled if multiple projects are being imported. However, if you select the "Ignore this Project" option for all projects but one, this tab is enabled.
  13. Click Save to update the existing template or click Save As to create a new template with a unique name. Click Next.
  14. Click Finish.
Notes
Last Published Monday, November 6, 2023
