Add Then and Else statements
- Choose Tools, Global Change.
- Click New, or select an existing specification and click Modify.
- Click in the Then section to define a Then statement and in the Else section to define an Else statement.
- Click Add.
- In the Parameter field, select a data item.
- In the Parameter/Value field, select a data item to use as the first parameter in the statement. Select Custom to type a text or numeric value.
- Select an operator to define an arithmetic equation to change numeric data.
Arithmetic operators can connect two data items, a data item and a number, or two numbers. - Depending on the data items selected for the first parameter, either type a value in the second Parameter/Value field, or select it from a predefined list.
If the first parameter requires a valued definition rather than a second parameter, you can leave this field empty.
Note
- You can define Then statements without defining either an If statement or an Else statement. To define an Else statement, you must first define an If statement.
Related Topics
Last Published Wednesday, March 5, 2025
