Baseline Duplicates dialog box
Use the Baseline Duplicates dialog box to choose whether to renumber selected activity IDs in the baselines when you are renumbering activity IDs.
The top section of this dialog box lists baselines associated with the current project that P6 Professional will not update because doing so would create duplicate activity IDs; P6 Professional does not update activity IDs in a baseline if it detects that doing so would create duplicate activity IDs.
The bottom section of this dialog box presents you with a Yes or No choice whether to continue renumbering.
- Click Yes to renumber the selected activity IDs in the baselines that do not contain duplicates.
Be aware that once you click Yes, the changes are committed to the database with no chance for you to undo the renumbering. Furthermore, if you click Yes, the baselines listed in the Baseline Duplicates dialog box will not synchronize with the current project, which impacts the accuracy of comparison data and earned value if these baselines are subsequently used against the current project. - Click No to cancel the renumbering process for baselines and to undo renumbering in the current project.
Note
- This dialog box appears if you marked the Renumber Selected Activities in Baselines checkbox in the Renumber Activity IDs dialog box and P6 Professional subsequently detects baselines where duplicate activity IDs would be created.
Last Published Wednesday, March 5, 2025
