Check in a project from XML
- Open the projects you want to check in.
- Choose File, Check In.
- Select the file you want to check in.
- Double click the Import Action field to select how the project data is checked in.
Select Update Existing Project to update with any new new/modified date in the XML file.
Select Replace Existing Project to delete the existing project and replace it with the project checked in from the XML file
Select Ignore this Project to not check in the project. - Optionally select the data to check in by editing the template in the Update Project Options dialog box.
- If you are connected to a P6 EPPM database, select the currency for the projects in the Currency Type dialog box.
- Click Finish.
Note
- To move between different wizard windows, click Prev or Next.
Last Published Wednesday, March 5, 2025
