Delete EPS level activity codes
Structuring Projects > Defining Project, Resource, and Activity Codes > Activity Codes > Defining EPS-level Activity Codes and Values and Values Colors
- Choose Enterprise, Activity Codes.
- Choose EPS, then click Modify.
- Select the code you want to delete, then click Delete.
- Click Yes.
Note
- When you delete an EPS-level activity code, all code values associated with the deleted activity code and all activity assignments to those activity code values are automatically deleted.
Last Published Wednesday, March 5, 2025
