Delete Resource dialog box
Use the Delete Resource dialog box to specify how you want to delete a resource.
Note: In most circumstances you should not delete resources. Instead, clear the Active checkbox.
The selected resource has the following associated data: The selected resource's associated data.
Select Replacement Resource: Choose to delete the selected resource and reassign its associated data to a resource that you specify.
Delete selected resource: Choose to delete the selected resource without reassigning its associated data.
Last Published Wednesday, March 5, 2025
