Modify Template dialog box
Use the Modify Template dialog box to select the options used when importing and exporting data for use with Microsoft Project or other third-party applications.
If resource security is enabled, some restrictions apply when importing resource and resource assignments. For details, click the Resource link below.
The following tabs are available:
- General tab - Modify Template dialog box
- WBS tab - Modify Template dialog box
- Global tab - Modify Template dialog box (P6 EPPM Only)
- Project tab - Modify Template dialog box (P6 EPPM Only)
- Activity tab - Modify Template dialog box
- Resource tab - Modify Template dialog box
- Notebooks tab - Modify Template dialog box
- Custom Field Mappings tab - Modify Template dialog box
Related Topics
Introduction to Resource Security
Last Published Wednesday, March 5, 2025
