Project Codes dialog box
Use the Project Codes dialog box to create, edit, and delete global and project codes and values. Use these codes and values to sort, filter, group, and report activity information.
Select Project Code: The name of the current project code. You can select a different code.
Modify: Allows you to create, modify, or delete project codes.
Display Options bar: Click to search for a specific project code value and change the project codes display.
Code Value: Lists code values for the current project code. To change a value, double-click it. To sort the display, click the Code Value column label.
Code Description: Lists each project code value's description.
Add: Adds a value to the current project code.
Delete: Deletes the selected value from the current project code.
Cut: Cuts the selected code value so you can move it to another position in the list. Select a new position, and click Paste.
Copy: Copies the selected code value so you can quickly create a similar value in another position in the list. Select a new position, and click Paste.
Paste: Pastes a code value you copied or cut.
Arrows: Moves the selected value to a different position in the display. This changes the order in which the values display when you assign a value to an activity.
Note
Last Published Wednesday, March 5, 2025
