Select a Portfolio dialog box
Display Options bar: Click to change your portfolio display. You can change the table font, color, and row height or expand/collapse all bands.
Portfolio Name: Lists all portfolios the user has access to.
OK: Click to select the highlighted portfolio. You cannot select a band.
For Oracle only
Display: Choose to display only the EPS bands for the projects in the selected portfolio (to improve performance) or all EPS bands. When you choose to display EPS bands only for projects in current Portfolio, all parent EPS nodes of projects in the portfolio load, not just the first parent.
Last Published Wednesday, March 5, 2025
