Select Activities by WBS dialog box
Use the Select Activities by WBS dialog box to specify which of the activities for a selected WBS you want to include in your project plan.
Display Options bar: Click to change the activities display.
Activity table: Lists activities in the selected WBS. A checkmark indicates that the activity is selected.
Tip
- To sort the display, click a column label.
Last Published Wednesday, March 5, 2025
