Select Curve dialog box
Use the Select Curve dialog box to choose the resource curve you want to assign to a resource or role assignment.
Display Options bar: Click to change the display.
Resource Curve Name: Lists all defined default and global resource curves. Select the curve you want to assign.
Select: Click to assign the selected curve to your resource or role assignment.
Clear: Click to remove the selected curve from your resource or role assignment.
Last Published Wednesday, March 5, 2025
