Select Financial Period dialog box
Use the Select Financial Period dialog box to select a financial period for storing period performance or to select a range of financial periods to make available for display as columns.
Period Name: Displays the name of each defined period in the Financial Period dictionary.
Start Date: Displays the start date of each period.
End Date: Displays the end date of each period.
Notes
- You can only select one financial period at a time.
- You can skip periods when storing period performance for a project; however, past period actual values will not be spread after the gap in periods.
Last Published Wednesday, March 5, 2025
