Select Project dialog box
Use the Select Project dialog box to select a project when prompted.
Display Options bar: Click to change the projects table display.
Projects table: Lists projects and related information. To sort the display, click a column label.
Select: Selects the highlighted project.
Last Published Wednesday, March 5, 2025
