Apply Gantt Chart settings from another layout
- Choose View, Bars.
You can also click the Layout Options bar and choose Bars. - Click Copy From.
- Select the layout with the Gantt Chart settings you want to apply.
To view the Gantt Chart settings, click Apply.
To apply the selected layout's Gantt Chart settings and close the dialog box, click Open.
Last Published Wednesday, March 5, 2025
