Check out a project to XML
  1. Open the projects you want to check out.
  2. Choose File, Check Out...
  3. Select the projects you want to check out.
    To check out a project, it must be open. If the project you want to check out is not on the list, click Cancel, open the project, and restart the wizard.
  4. Select Check out to XML.
  5. Click Finish.
    An XML file is created that exports complete project information to other P6 Professional or P6 EPPM applications.
Note
Last Published Wednesday, March 5, 2025
