Copy and paste a project
  1. Open the project you want to copy
  2. Choose Enterprise, Projects, then select the project you want to copy.
  3. Choose Edit, Copy, or click the Copy icon on the Edit toolbar.
  4. Select the position in the EPS where you want to copy the project.
  5. Choose Edit, Paste, or click Paste icon on the Edit toolbar.
  6. In the Copy Project Options dialog box, mark the checkbox next to each type of information you want to copy.
  7. Click OK.
Notes
Related Topics
Managing projects using the EPS
EPS (Enterprise Project Structure)
Last Published Wednesday, March 5, 2025
