Copy Resource Options dialog box
The Copy Resource Options dialog box allows you to specify which information you want to copy when you copy a resource.
You may copy any or all of the following options:
Sub-Resources: Mark to copy all resources contained in the resource you want to copy.
Role Assignments: Mark to copy the resource's role assignments.
Prices: Mark to copy the resource's price information.
Do not show this window again: Mark to indicate that you do not want this dialog box to appear next time you copy a resource.
Note
- If you mark Do not show this window again, the Copy Resource Options dialog box will not display again until you restart the application.
Last Published Wednesday, March 5, 2025
