Create project-level activity codes
  1. Choose Enterprise, Activity Codes.
  2. Choose Project, then click Modify.
  3. Select the project to which you want to add the activity code and click Add.
  4. Type the name of the project activity code.
  5. In the Max Length field, specify the maximum number of characters for the activity code's values.
  6. Click Close.
Tip
Last Published Wednesday, March 5, 2025
