Customize a Resource Analysis layout
You can customize an existing Resource Analysis layout by specifying options that determine the data that are displayed and how they are displayed.
- In the window displaying the layout, click the Display Options bar and choose Top Layout Options or Bottom Layout Options, then choose the type of information you want to change.
The Resource Explorer window displays to the left of the Bottom Layout window. You select resource elements in this window to control the data that you want to display in the resource profile or spreadsheet. You can filter, group, and sort the resource information in this window. You can also change the font, colors, and row height and specify which columns are included.
- To change the Resource Explorer window options, click the Display Options bar in the Resource Explorer window, then choose the appropriate option.
For the Gantt Chart and column data that display next to the chart in the Top Layout window, you can
- Specify the bar and column data you want to display
- Filter the bar and column data
- Group and sort the bar and column data
- Specify the font, table color, and row height for the columns
- Set the Gantt Chart timescale
When you display the profile or spreadsheet, you can configure the following options in the Top and Bottom Layout windows
- Specify the profile and spreadsheet data you want to display
- Specify the columns you want to include next to the spreadsheet display
- Filter the profile and spreadsheet data
- Specify the font, table color, and row height for the spreadsheet
- Specify the profile bar, curve, and graph display options
- Set the timescale
When you display the stacked histogram for the profile, you can configure the following options in the Bottom Layout window
- Specify the profile data you want to display
- Specify the profile curve and graph display options
- Specify the profile patterns and colors for the selected resource filters
- Set the timescale
Note
- When you adjust the timescale, it affects both the Top and Bottom Layout windows.
Related Topics
Last Published Wednesday, March 5, 2025
