Customize the activity box layout
- Display the Activity Network in the Activities window, then choose View, Activity Network, Activity Network Options.
You can also click the Layout Options bar, then choose Activity Network, Activity Network Options. - Click the Activity Box Template tab.
- Click Box Template.
- To add a field to the activity boxes, click Add.
Click the Field Name column, then select the field you want to display.
Double-click the Width column, then specify the width of the field.
Double-click the Height column, then specify the height of the field.
See More Detail: Specifying activity box field widths for more information. - To position the field within the activity box, click
and
. - To remove a field, select it, then click Delete.
- Click OK.
Tips
- To copy the activity box layout from another activity layout, click Copy From, select the layout whose activity box layout you want to copy, then click Open.
- To change the width of the Activity Network activity boxes, specify a new box width in the Total Width field.
Related Topics
Last Published Wednesday, March 5, 2025
