Search only in titles Delete project codes Structuring Projects > Defining Project, Resource, and Activity Codes > Project Codes Choose Enterprise, Project Codes. Click Modify. Select the code you want to delete, then click Delete. Click Yes. Last Published Wednesday, March 5, 2025
