Edit resource code values
  1. Choose Enterprise, Resource Codes.
  2. Select the resource code whose value you want to change.
  3. To change a value or description, double-click the item you want to change, then type the new text.
Tip
Related Topics
Edit resource codes
Last Published Wednesday, March 5, 2025
