Edit role codes
- Choose Enterprise, Role Codes.
- Click Modify.
- Select the role code you want to edit.
To change the role code's name, type a new name.
To change the maximum number of characters the code's values may have, specify a new number.
To change the placement of the code in the list, click Shift Up or Shift Down. - Click Close.
Tip
- If you change a role code, your changes apply to all role assignments.
Last Published Wednesday, March 5, 2025
