Enable or disable auto-reorganization
The module automatically reorganizes data in the current window according to the group and sort criteria specified for the window when you add or move data, unless you disable auto-reorganization. Do one of the following:
Tips
Related Topics
Reorganizing window data automatically
Last Published Wednesday, March 5, 2025
