Print Preview dialog box
Use the Print Preview dialog box to preview the selected report before printing or saving the report.
Allows you to define the displayed report's header and footer, margins, print size, and page orientation.
Allows you to select the default printer, print size, and page orientation.
Prints the displayed report.
Outputs the report to an HTML file and location you specify and automatically launches your default browser to display the report.
Displays the first page of the displayed report.
Displays the next page to the left, if multiple pages are printed horizontally.
Displays the next page to the right, if multiple pages are printed horizontally.
Displays the previous page back, if multiple pages are printed vertically.
Displays the next page forward, if multiple pages are printed vertically.
Displays the last page of the displayed report.
Magnifies your view of the displayed report.
Reduces your view of the displayed report.
Opens Help.
Closes this dialog box.
Last Published Wednesday, March 5, 2025
