Project Issues window
Use the Project Issues window to add, edit, and delete issues for the open project and to send Email notifications about issues. You can customize the columns that display in the issue table, and you can group, sort, and filter issues.
To display the Project Issues window, do one of the following:
When working in the Project Issues window, you can:
Tip
Notes
Related Concepts
Related Tasks
You can perform all of the following tasks in the Project Issues window:
Related Topics
Project Toolbar
Menu bar
Edit Toolbar
Layout Toolbar
Project Issue Details
Bottom Layout Toolbar
Use the issue navigator
Introduction to Resource Security
Root Node
Current Project Resources
Issues
View or add to an issue's history
Track the duration of an issue
Send Email about an issue
Delete an issue
Change an issue's status
Assign an issue to an activity
Assign an issue to a resource
Assign a tracking layout to an issue
Add an issue
Last Published Wednesday, March 5, 2025
