Risks view (P6 Professional Only)
Use the Risks view to add, edit, and delete risks for the open project. You can also assign risks to activities, define risk impact, select a response, and define new impacts based on the response. You can customize the columns that display in the risk table, and you can group, sort, and filter risks.
To display the Risks view, do one of the following:
- Click
on the Project toolbar. - On the Project menu, choose Risks.
When working in the Risks view, you can:
- Use the Edit menu or Edit toolbar to add, delete, cut, copy, and paste risks.
- Use the Display Options bar, View menu, or Layout toolbar to customize the risk table.
- Use Risk Details or the risk table to define general and detailed information for each risk. To show or hide Risk Details, click
on the Bottom Layout toolbar.
Notes
- After opening the Risks view, the window remains open until you close all open projects or you close the window; if you open or navigate to another window without closing the Risks view, click the Risks tab to return to the window at any time.
- If resource security is enabled, you can only view resources you have access to (under the resource root node) and current project resources.
Related Concepts
- Risks
Related Tasks
You can perform all of the following tasks in the Risks view:
- Creating Risks
- Assigning a risk to an activity
- Responding to a risk
- Deleting a risk
- Modifying a risk
- Removing risk assignments from activities
Related Topics
Risks Details (P6 Professional Only)
Introduction to Resource Security
Removing risk assignments from activities (P6 Professional Only)
Modifying a risk (P6 Professional Only)
Responding to a risk (P6 Professional Only)
Assigning a risk to an activity (P6 Professional Only)
Creating Risks (P6 Professional Only)
Last Published Wednesday, March 5, 2025
