Schedule Options dialog box
The Schedule Options dialog box is displayed when you open a project or set of projects for scheduling. This dialog box contains the following tabs:
Use scheduling options from: If multiple projects are open, select which projects scheduling options to use when you schedule.
Default: Displays and/or applies the default scheduling settings.
Related Topics
Advanced tab - Schedule Options dialog box
General tab - Schedule Options dialog box
Last Published Wednesday, March 5, 2025
