Specify a format for dates
- Choose Edit, User Preferences.
- Click the Dates tab.
- In the Date Format section, select the order in which you want all dates to appear.
- In the Time section, specify how or whether you want to display time.
- In the Options section, select the date formatting options you want to apply.
Last Published Wednesday, March 5, 2025
