Create a project calendar
- Choose Enterprise, Calendars, then choose Project.
 - If more than one project is open, select the projects to which you want to add a calendar, then click Add.
 - Select the calendar you want to copy for the new project calendar, then click the Select button.
 - Type the new calendar's name.
 - Click Modify and edit the new calendar.
Last Published Wednesday, March 5, 2025
