Create project codes
  1. Choose Enterprise, Project Codes.
  2. Click Modify.
  3. Click Add, then type the name of the project code.
  4. In the Max Length field, specify the maximum number of characters for the project code's values.
  5. Click Close.
Note
Tip
Last Published Wednesday, March 5, 2025
