Edit EPS-level activity code values
Structuring Projects > Defining Project, Resource, and Activity Codes > Activity Codes > Defining EPS-level Activity Codes and Values and Values Colors
- Choose Enterprise, Activity Codes.
 - Choose EPS.
 - Select the code whose value you want to change.
 - To change a value or description, double-click the item you want to change, then type the new text.
To change the placement of the code in the list, click the appropriate arrow. - Click Close.
Tip
- If you change an activity code value, your changes apply to all activity assignments.
Last Published Wednesday, March 5, 2025
