Edit EPS-level activity codes
Structuring Projects > Defining Project, Resource, and Activity Codes > Activity Codes > Defining EPS-level Activity Codes and Values and Values Colors
- Choose Enterprise, Activity Codes.
 - Choose EPS, then click Modify.
 - Select the activity code you want to edit.
To change the code's name, type a new name.
To change the maximum number of characters the code's values may have, specify a new number.
To change the placement of the code in the list, click Shift Up or Shift Down. - Click Close.
Tips
- If you change an activity code, your changes apply to all activity assignments.
 - Any code associated with an EPS-level you do not have access to, will appear under "No EPS ID". You can not modify or delete EPS-level activity codes listed under "No EPS ID".
Last Published Wednesday, March 5, 2025
