Edit global activity code values
Structuring Projects > Defining Project, Resource, and Activity Codes > Activity Codes > Defining Global Activity Codes and Values and Values Colors
- Choose Enterprise, Activity Codes.
 - Choose Global.
 - Select the activity code whose value you want to change.
To change a value name or description, double-click the item you want to change, then type the new text.
To change the placement of the code in the list, click Shift Up or Shift Down. - Click Close.
Tip
- If you change an activity code value, your changes apply to all activity assignments.
Related Topics
Last Published Wednesday, March 5, 2025
