Edit project code values
- Choose Enterprise, Project Codes.
 - Select the project code whose value you want to change.
 - To change a value or description, double-click the item you want to change, then type the new text.
Tip
- If you change a project code value, your changes apply to all project assignments.
Related Topics
Last Published Wednesday, March 5, 2025
