Modify a column's title, width, and alignment
  1. With the Tracking window active:
    To customize columns in the Top Layout, choose View, Columns, Customize. You can also click the Display Options bar and choose Top Layout Options, Columns, Customize.
    To customize columns in the Bottom Layout, right-click in the table and choose Columns, Customize.
  2. In the Selected Options area, select the column whose title you want to change, then click Edit Column.
  3. Type a new title, then specify its width and choose an alignment.
Note
Related Topics
Define columns for a tracking layout
Last Published Wednesday, March 5, 2025
