Linking P6 and Oracle Primavera Cloud Applications.
Perform the steps below to link P6 to Oracle Primavera Cloud. This link at the application level allows you to establish links at the project level. When the applications and projects are linked, P6 users can send data to Oracle Primavera Cloud.
To link P6 and Oracle Primavera Cloud applications:
- Click Administration.
- On the Administration navigation bar, click Application Settings.
- On the Application Settings page, click the Gateway tab.
- On the Gateway tab in the Primavera Gateway Parameters section:
- Enter the URL of the Primavera Gateway server in the API Url field of the Primavera Gateway Parameters section.
- Enter a Primavera Gateway username in the Username field.
- Enter a Primavera Gateway password in the Password field.
- Click Test Connection.
Note: If the connection test fails, contact your Primavera Gateway administrator.
- Enter a Primavera Gateway deployment name into the P6 Deployment field.
- On the Gateway tab in the Integration Parameters section:
- Click Add.
- Select an action from the Action Type list.
- Select a deployment from the Source/Destination Deployment list.
- Select a synchronization from the Synchronization list.
- Enter a name in the Action Name field.
- Click Save and Close.
Note: You need the Edit Application Settings privilege to edit the settings on the Application Settings pane.
Related Topics
Working With Primavera Gateway
Linking P6 and Primavera Unifier Applications Using Summary Sheets
Last Published Wednesday, July 10, 2024
