Transferring Data Between P6 and Oracle Primavera Cloud
You can send data for a linked P6 project to Oracle Primavera Cloud and retrieve data from the linked project in Oracle Primavera Cloud to update your P6 project.
To transfer data between P6 and Oracle Primavera Cloud:
- Click Projects.
- On the Projects navigation bar, click Activities.
- In the Activities page click the Actions
menu and select Exchange Data and and then select the menu option for sending data to Oracle Primavera Cloud.
Tips:
- The option for sending data to Oracle Primavera Cloud will be available if your administrator has configured the integration options.
- Data can also be transferred between P6 EPPM and Oracle Primavera Cloud from within Oracle Primavera Cloud and Primavera Gateway.
Related Topics
Linking P6 and Oracle Primavera Cloud Applications.
Last Published Wednesday, July 10, 2024
