Top=
3. ELCM Integration with External System
Oracle Banking Enterprise Limits and Collateral Management system
(OBELCM) supports Oracle Banking Enterprise Limits Management system
(OBELM) and Oracle Banking Enterprise Collateral Management system (OBECM)
as a separate installation. In addition, it supports integration with
external ELM/ECM systems.
You can use OBELM or OBECM to support seamless integration with external
ELM/ECM systems.
3.1 OBELM and OBECM co-deployed
No changes to this functionality as these modules are co-deployed.
3.2 OBELM with External ECM
- OBELM system provides external collateral pool service to populate
the pool details and valid limit service to fetch the liability details
of the customer.
- External ECM system creates the collateral pool in OBELM system by
using the services exposed.
- External ECM system provides collateral block service to update collateral
details.
- OBELM system calls the collateral block service for any change in
the pools linked to facility.
3.3 OBECM and External ELM
- OBECM system provides the collateral block service and valid limit
service. Valid limit service fetches the liability and collateral details
for any customer.
- External ELM system uses the services exposed to get the collateral
details for facility creation.
- External ELM system calls the collateral block service for any change
in the collaterals linked to facility.
3.4 OBECM and OBELM deployed separately
of the customer.
- OBECM system creates the collateral pool in OBELM system by using
- OBECM system provides collateral block service to update collateral
details and valid limit service to fetch liability details.
3.5 Maintenances for OBELM and OBECM
3.5.1 Valid Limit Service
The Valid Limit Service (GEDQVLLN) is modified to fetch the limit
details based on limit type.
For more information on valid limit service, refer to Querying Valid
Lines section.
3.5.2 External Collaterals Pool Service
The External Collaterals Pool (GCDEPOOL) service has been created
to populate pool details from the external system.
This screen populates the data from the external system. You can invoke
this screen by typing ‘GCDEPOOL’ in the field at the top right corner
of the Application tool bar and clicking on the adjoining arrow button.
3.6 Assumptions
- Same customer and liability should exist in both the systems.
- Service end points are provided
- External ELM system is dependent on OBECM collaterals for facility
creation
- External ECM system populates the pool details prior to facility
creation
